Connection goes Offline after about 4 days of inactivity?!?
bmathews23bmathews23 Posts: 3
in Connectivity Apr 02, 2018
So, like many others, I've been having horrible connection issues. This has been off and on since December 2017.  I really noticed the poor performance after installing a Nest thermostat.  It would go offline after a couple of days once we left.
I had a personally owned combo router/modem SB 6580.  I was told by Comcast that the combo unit was the issue and needed to be replaced.  Oh, not even a year old!  So, I bought an Netgear CM500 Modem and R6700v2 router. Surprise, Surprise, it had the same problem.   Hardware related?  Highly doubt it!
After I reboot my modem/router everything is fine for a short time.
I had a tech come out (3.16.18) and stated everything looked “great” and that the modem will go to sleep after a week of inactivity.  That’s a “nice” feature when paying a good chunk of money every month.  Why is it that my neighbors who use there’s less than mine not go out?
My connection actually went out agin while I was here and I called support again.  They sent out a “Senior” tech the next day (3.17.18).  He replaced all the connections outside stating that if they are even a little corroded it will cause drop connections.  Sounds good to me.  He ran tests and everything looks good.
So about 4 days later after leaving I tried to check on my Nest Thermostat and it was offline.  I called support to have another tech come out today (4.2.18) - we will see what they say.
Here is a snippet of the modem logs (xx out some of Mac):
2018-4-1, 16:05:15
Critical (3)
No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:21
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:26
Notice (6)
Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
2018-4-1, 16:07:53
Error (4)
Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.1;CM-VER=3.0;
2018-4-1, 16:07:53
Error (4)
Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.1;CM-VER=3.0;
2018-4-1, 16:46:15
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.1;CM-VER=3.0;
2018-4-1, 16:47:04
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.1;CM-VER=3.0;
2018-4-1, 16:47:13
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.0;CM-VER=3.0;
2018-4-1, 16:52:28
Warning (5)
B-INIT-RNG Failure - Retries exceeded;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:17:10:8a:a5:29;CM-QOS=1.0;CM-VER=3.0;
2018-4-1, 16:52:29
Critical (3)
2018-4-1, 16:57:02
Warning (5)
2018-4-1, 16:57:03
Critical (3)
2018-4-1, 17:02:14
Warning (5)
2018-4-1, 17:02:15
Critical (3)
2018-4-1, 17:06:50
Warning (5)
2018-4-1, 17:06:51
Critical (3)
2018-4-1, 17:13:55
Warning (5)
2018-4-1, 17:13:56
Critical (3)
2018-4-1, 17:18:55
Warning (5)
2018-4-1, 17:18:56
Critical (3)
2018-4-1, 17:18:57
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=a0:xx:xx:xx:xx:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2018-4-1, 17:18:57
Critical (3)
2018-4-1, 17:19:05
Critical (3)
2018-4-1, 17:19:05
Critical (3)
2018-4-1, 17:19:25
Notice (6)
2018-4-1, 17:19:38
Error (4)
2018-4-1, 17:19:38
Error (4)
  • bmathews23bmathews23 Posts: 3
    Apr 04, 2018 Accepted Answer
    quick update: had a tech come out (3rd visit) and he replaced all the fittings outside.  My Uncorrectables have gone to zero now!!
    Lets hope this resolves the issue once and for all.  If anything changes I will update this post.
    Equipment:
    Netgear CM500 Modem (Firmware V1.01.09)
    Nighthawk R6700v2 (Router Firmware Version V1.2.0.16_1.0.1)
    Apr 02, 2018
    The SB6183 is not a combo unit...it is a modem only.
    Post the signal levels page as well.
    Apr 02, 2018
    Apologies typo ...  SB 6580
    Startup Procedure
    Procedure
    Status
    Comment
    Acquire Downstream Channel
    519000000 Hz
    Locked
    Connectivity State
    OK
    Operational
    Boot State
    OK
    Operational
    Security
    Enabled
    BPI+
    IP Provisioning Mode
    IPv6 Only
    ipv6Only(1)
    Downstream Bonded Channels
    Channel
    Lock Status
    Modulation
    Channel ID
    Frequency
    Power
    SNR
    Correctables
    Uncorrectables
    Locked
    QAM256
    11
    519000000 Hz
    2.9 dBmV
    42.8 dB
    182
    1012
    2
    Locked
    QAM256
    10
    513000000 Hz
    3.1 dBmV
    43 dB
    133
    664
    3
    Locked
    QAM256
    25
    603000000 Hz
    2.9 dBmV
    42.5 dB
    188
    1003
    4
    Locked
    QAM256
    12
    525000000 Hz
    2.8 dBmV
    42.6 dB
    205
    988
    5
    Locked
    QAM256
    13
    531000000 Hz
    2.5 dBmV
    42.4 dB
    194
    997
    6
    Locked
    QAM256
    14
    537000000 Hz
    2.4 dBmV
    42.4 dB
    173
    1018
    7
    Locked
    QAM256
    15
    543000000 Hz
    2.4 dBmV
    42.4 dB
    185
    1007
    8
    Locked
    QAM256
    16
    549000000 Hz
    2.5 dBmV
    42.5 dB
    9
    Locked
    QAM256
    17
    555000000 Hz
    2.1 dBmV
    42 dB
    196
    993
    10
    Locked
    QAM256
    18
    561000000 Hz
    2.5 dBmV
    42.5 dB
    134
    671
    11
    Locked
    QAM256
    19
    567000000 Hz
    2.4 dBmV
    42.3 dB
    193
    1001
    12
    Locked
    QAM256
    20
    573000000 Hz
    2.4 dBmV
    42.2 dB
    182
    1012
    13
    Locked
    QAM256
    21
    579000000 Hz
    2.7 dBmV
    42.4 dB
    166
    1026
    14
    Locked
    QAM256
    22
    585000000 Hz
    2.9 dBmV
    42.4 dB
    189
    1005
    15
    Locked
    QAM256
    23
    591000000 Hz
    3.1 dBmV
    42.6 dB
    182
    1008
    16
    Locked
    QAM256
    24
    597000000 Hz
    2.9 dBmV
    42.3 dB
    187
    1004
    Upstream Bonded Channels
    Channel
    Lock Status
    US Channel Type
    Channel ID
    Symbol Rate
    Frequency
    Power
    Locked
    ATDMA
    6
    5120 Ksym/sec
    24000000 Hz
    43.3 dBmV
    2
    Locked
    TDMA
    5
    2560 Ksym/sec
    19200000 Hz
    43.3 dBmV
    3
    Locked
    ATDMA
    7
    5120 Ksym/sec
    30400000 Hz
    43.3 dBmV
    4
    Locked
    ATDMA
    8
    5120 Ksym/sec
    36800000 Hz
    45.8 dBmV
    Current System Time:Mon Apr 02 08:43:00 2018
  • karlbeckmankarlbeckman Posts: 2,208 ✭✭✭✭
    Apr 02, 2018
     If you have an all-in-one gateway, your device would most likely be a Motorola SurfBoard SBG6580.  All-in-one is a configuration that folks on the forums generally don't recommend using.  Second, you don't need to blank parts of your device's MAC address - it only is used over the local physical link (ethernet cable or WiFi) between the modem and computer, or to an external router if you use one.  The MAC is not sent to other parts of the internet.  And third, remember that this box does not support IPv6 addressing on the LAN ports.
    Thanks for sending the signal levels screen report which tells us a lot. In particular, note the high number of uncorrectible errors on each downstream bonded channel, compared to correctables that your modem can fix for itself.  You've got incoming noise from the cable company drop which is occasionally going to cause network disconnects of the Nest equipment.  Nest won't restore the connection unless you assign a STATIC IP address in the router to each Nest device running over wire or WiFi.   You can learn how to do this by reading your modem's user guide.
    You say you've been having this problem for about 15 months.  Have you ever contacted your cable company about getting a signal analysis and repair of the cable at your home?  We highly recommend that as a first step!
    Apr 04, 2018
    Now there's a success story that didn't even require help from the Forum!  Congrats to you and your very competent Spectrum service tech.
