My phone not accepting incoming calls
Stubby13004Stubby13004 Posts: 4
in Digital Phone Jun 23, 2018
I have been unable to get incoming calls . I reset the modem and then it could get some calls that would only last 30 seconds then disconnect. I spent about an hour on cell phone with support. They had me give them a call back number I gave my cell number 3 times for obvious reasons. They said I would get a call . My app is saying they tried 2 times to call my home phone which is now not working again.
  • SatchSatch Posts: 3,636 helper
    Jun 23, 2018
    Hi Stubby,
    You will need to set up a service call to check your signals and drop line.  Don't reset any equipment, (boxes, modems, or routers, ) for six hours as the tech will need to see the signal error codes.  Since you have already done the modem reset, and the problem persists, a tech will need to be dispatched to check your signals, lines, wiring, and modem itself.
  • Stubby13004Stubby13004 Posts: 4
    Jun 23, 2018
    They are supposed to call me , but they only try on my home phone, it says on my cell app that they called .
    Jun 23, 2018
    Sup?
    I would say since you are having phone problems, get a Twitter Account or log into Twitter and follow the Ask Spectrum page.  Send a Direct Message on Twitter with your account information, that your Spectrum Phone service does not work and you need to schedule a signal and drop line test.  Let them know that you can't get a confirmation call via your landline because your phone is not working.  Here is the page:
    https://twitter.com/ask_spectrum?lang=en
    Set up the confirmation through your cell phone. Or some other contact,  Please contact us back if this does not work out for you.
    Jun 24, 2018
    I have called them again and the guy decided to reboot modem right away even after reading report. I did get service to come out and modem was replaced. It no longer disconnects after 30 seconds. This morning my tv and app said I was getting a call but no ringing. I checked phone and was a dial tone. I spoke to person who tried to call and they said it was a busy tone. It has only happened the one time so far so I don't know how bad it is .
  • Julia_RJulia_R Posts: 4,186 Lead Mod
    Jun 24, 2018
    Hi @Stubby13004
    Have you tried a different physical telephone?
    Are you using a cordless or corded phone?
    Does the phone plug directly into the modem or are  you using your house wiring currently?
    If you do a test call home on say a cellular telephone now do you get a ring or a busy signal?
    If you are getting a busy signal try and unplug your phone from the modem and do another test call. Do you get a ring then?
    If you get a busy signal with the phone plugged in but get a ring when there is no phone plugged into the modem it would point to a problem with the telephone equipment.
    Regards,
    Julia R.
    Jun 24, 2018
    Julia_R
    Since the service call, it has not received only 1 call, but it has not disconnected anymore. The original problem did on all phones and even when plugged directly into the modem.
