SB6141 dropping connection randomly
chonbiechonbie Posts: 2
in Connectivity Jul 18, 2019
I'm having issues with internet connection dropping randomly. After a connection drop, all the blue lights on the cable modem will turn off and then cycle through green lights before turning blue again and then reinstating the connection. I believe there is an issue with Spectrum, but I do not know how to read the logs from my SB6141. Could you help decipher this info to see if I need to get a tech from Spectrum out to my place? Thank you for your help in advance, I appreciate it.
Downstream Bonding Channel Value
Channel ID15 13 14 16 17 19 20 21
Frequency645000000 Hz 633000000 Hz 639000000 Hz 651000000 Hz 657000000 Hz 669000000 Hz 675000000 Hz 681000000 Hz
Signal to Noise Ratio38 dB 38 dB 38 dB 38 dB 38 dB 38 dB 38 dB 38 dB
Downstream ModulationQAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Power Level
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
-3 dBmV  -3 dBmV  -3 dBmV  -3 dBmV  -4 dBmV  -3 dBmV  -4 dBmV  -4 dBmV
Upstream Bonding Channel Value
Channel ID50 52 51 49
Frequency24200000 Hz 37000000 Hz 30600000 Hz 17800000 Hz
Ranging Service ID11703 11703 11703 11703
Symbol Rate5.120 Msym/sec 5.120 Msym/sec 5.120 Msym/sec 5.120 Msym/sec
Power Level51 dBmV 51 dBmV 51 dBmV 51 dBmV
Upstream Modulation[3] QPSK
[1] 16QAM
[2] 64QAM
[3] QPSK
[1] 16QAM
[2] 64QAM
[3] QPSK
[1] 16QAM
[2] 64QAM
[3] QPSK
[1] 16QAM
[2] 64QAM
Ranging StatusSuccess Success Success Success
Signal Stats (Codewords) Bonding Channel Value
Total Unerrored Codewords6978434304 6897856057 6897864329 7136655261 7136636211 7136638774 7136640682 7136641538
Total Correctable Codewords59 48 16 944 555 343 364 380
Total Uncorrectable Codewords5245 5152 5058 12169 13351 12431 11519 11661
Time Priority Code Message
Jul 16 2019 03:47:246-NoticeI401.0TLV-11 - unrecognized OID;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 16 2019 03:47:245-WarningZ00.0MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:213-CriticalR02.0No Ranging Response received - T3 time-out;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:166-NoticeN/ACable Modem Reboot due to power reset ;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
Jul 12 2019 10:55:476-NoticeI401.0TLV-11 - unrecognized OID;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 12 2019 10:55:475-WarningZ00.0MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:223-CriticalR02.0No Ranging Response received - T3 time-out;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 12 2019 09:38:236-NoticeI401.0TLV-11 - unrecognized OID;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 12 2019 09:38:235-WarningZ00.0MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:243-CriticalR02.0No Ranging Response received - T3 time-out;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 07 2019 23:55:026-NoticeI401.0TLV-11 - unrecognized OID;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 07 2019 23:55:025-WarningZ00.0MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:233-CriticalR02.0No Ranging Response received - T3 time-out;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 07 2019 16:29:256-NoticeI401.0TLV-11 - unrecognized OID;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jul 07 2019 16:29:255-WarningZ00.0MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
Jan 01 1970 00:00:166-NoticeN/ACable Modem Reboot due to T4 timeout ;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
Jul 07 2019 16:28:323-CriticalR04.0Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=78:96:84:bc:7f:ff;CMTS-MAC=00:01:5c:6d:b2:70;CM-QOS=1.1;CM-VER=3.0;
    Jul 18, 2019
    The first thing to jump out to me are the high upstream power levels. At 51 dBmV the modem is having to scream to be heard. It's best to be in the 40-47 range.
    Can you describe your connection path from the tap at the pole or pedestal to the modem as best you can (splitters, length of coax runs, wall outlets, etc)?  House or apartment?
  • chonbiechonbie Posts: 2
    Jul 18, 2019
    I live in a large apartment complex (~100 units) so it's really difficult to say how everything is setup. There is only one coax wall outlet in my unit, and from there I'm not sure how things are setup. I do see a LOT of people's cable/internet coax lines about 75ft away in the trash chute room, but I'm unsure how everything is wired between my unit and the cables in the trash room.
    cable modem in my unitcable modem in my unitcables in trash chute roomcables in trash chute room
  • LGTLGT Posts: 94 ✭✭✭✭
    Jul 18, 2019
    Agree with the previous poster. Your upstream numbers are right against the high end for that modem. It will be hard for you personally to figure out what is happening in a large apartment building like you are in. The only option you probably have is to try to get a Spectrum tech out there to troubleshoot and hope they spot something.
  • RAIST5150RAIST5150 Posts: 634 ✭✭✭✭
    Jul 19, 2019
    YIKES!
    What is that... a 20 foot cable for a 30 inch run from the wall to the modem?
    Sure, it is likely RG6 so the loss is minimal... but for heavens sake, use a more appropriate length of cable so you don't have all that coiling and unnecessary signal loss. Already have an uphill battle with cabling because it is an apartment building, don't need to add to it unnecessarily.
    Jul 19, 2019
    Agreed...replace that extra long coax to the modem. If you can lower the upstream power levels even .5 dBmV it might make all the difference.
  • RoloX2RoloX2 Posts: 379
    Jul 20, 2019
    Having multiple winds in your cable like that creates an electromagnetic coil, causing interference
    Unwind it and don't use zip-ties
    Replace it with the right size cable (I've always asked the tech for the size I need and they've always just fabricated one on the spot)
