lights on receiver
rodney1234rodney1234 Posts: 61
in TV Equipment Nov 08, 2019
Does anybody else have their lights on receiver go out and then come on at random , nothing else is wrong ??
  • Geezer64Geezer64 Posts: 69
    Nov 09, 2019
    Not that i would know the answer but it would be helpful to those that may, if you were to list your model receiver and guide.  Hope you get it resolved.  Smiley Happy
  • SatchSatch Posts: 3,633 helper
    Nov 09, 2019
    Hi,
    Due to these boxes and swaps being so unpredictable.  (Some work great, some average, and some, not at all.)- if the functionality of your CATV service  is OK, don't even worry about a light.  You could get something far worse in a box swap.
    "Don't Rock the Boat if the Sea is Calm."
  • toolman1990toolman1990 Posts: 150 ✭✭✭
    Nov 09, 2019
    On the Arris HD set top box I was issued the white clock LED's brightness will fluctatue intermitently and it is noticeable when it happens. But if the set top box is working I would keep it and you can disable the clock in settings if it bothers you.
