**NEW** Advanced Search Options
We recently added advanced search options to make it easier to locate posts on the community.
Welcome to the Community!
DVD player and DVR issues
OHumphreyOHumphrey Posts: 1
edited January 5 in Watch TV 2020 Archive Jan 16, 2020
Ever since I switched to a DVR from a regular cable box, my DVD player no longer connects to the TV.  I have an old TV and use an RF Modulator.   I don't understand why the DVR became the problem, since all the connections were basically the same.  Any ideas about what to try? I had given up but want to try again.  Thanks.
  • dstoffadstoffa Posts: 1,014 ✭✭✭✭
    Jan 17, 2020
    You will need to describe your setup.  If your "old" TV is a CRT set, and doesn't even have compostie video in (which is why you are using the RF modulator), how are you selecting inputs?  Meaning, how do you change from (cable) TV to DVD?
