Sony remote will not control Spectrum 110
Jlm86Jlm86 Posts: 1
edited August 2 in TV Equipment Aug 02, 2020
I have a Sony 950G TV and the remote control setup for cable box will only control the volume of the cable box.
Need the guide button and other features to work..
I've tried using both types of boxes in setup
Spectrum 110
Arris 110
Remote is tx600u
Thank you
  • James_MJames_M Posts: 2,269 ADMIN
    Aug 05, 2020
    To control the cable box and the TV on one remote, you would need to program the Spectrum remote for the cable box to also control the TV. It sounds like the TV remote is not compatible to the cable box.
  • SatchSatch Posts: 3,714 helper
    edited August 7 Aug 07, 2020
    What is the model number of the Spectrum Remote that you have with your Spectrum receiver? By providing that, we can than link you to the "Programing Your Remote" page for that Spectrum Remote. By entering the set-up codes for your Spectrum TV into your Spectrum remote, you should be able to control the following functions using your Spectrum Remote:
    TV and box on/off functionality.
    Mute and Volume Control.
    All Cable TV Guide and Cable Box Settings functions..
    You would than only use the remote that comes with your TV to program settings that are specific to your TV like color and brightness settings. Typically, you will only need to re-enter your TV manufacturer settings into your Spectrum remote if you:
    1.) Get a new TV
    2.) Get a new Spectrum remote.
