Welcome to the Community!
is nicked cable causing connectivity issue?
dcondcon Posts: 13 ✭✭✭
edited August 2020 in Connectivity Aug 23, 2020
I seem to lose connectivity to all devices, including phone, about once per day. I have replaced the gateway with Spectrum's TC8717T, and when that didn't help, I had them reset/update firmware remotely via a phone call. Still happening. Recently I saw in my flower bed near my house connection a place where perhaps a gardening tool may have nicked the cable. Metal is showing and it looks like there is some fraying of the metal shielding. I know it's not ideal, but could it be causing my issues? I will post a pic and a screenshot of my power levels. Any thoughts most appreciated!
    edited August 2020 Aug 23, 2020
    dcon, your signal levels and SNRs look fine, but the nick is a serious problem and the cable needs to be replaced ASAP! Good luck and enjoy, John.
    EDIT: It would be useful to see the same screenshot when your lose your service.
    Signals look decent on that lower end in the snapshot, but the noise floor may be questionable at the higher end.
    Compromised cabling should be addressed regardless... it is important not only to avoid signal leaking/ingress, but also the shape of the waveforms traveling through the cable.
  • dcondcon Posts: 13 ✭✭✭
    Aug 23, 2020
    thank you to @misterj , @RAIST5150 , and @Julia_R for your help. @Julia_R , I appreciate whatever you can do from your side.
