Frequently Asked Questions
Will I have to reset the remote after changing batteries?
deedleann824deedleann824 Posts: 37 Participant
edited November 8 in TV Equipment Oct 06, 2022
It's model UR3-SR3S.
  • SatchSatch Posts: 4,754 Contributor
    Oct 06, 2022 Answer ✓
    Generally no. The remote will hold the memory codes for five to ten years. I have found the default code that most remotes reset to is for Samsung TV's, If you have a Samsung set, my experience is that the remotes will work right out of the box. Simply run the set-up program if they don't.
