Samsung The Frame Remote can't control Cisco 9865?
reefdude
reefdude Posts: 3 Spectator
edited November 20 in TV Equipment
I just got a replacement DVR and it different than my last box. It is the Cisco 9865_2 and I am unable to get the Samsung universal remote to control this box at all.
Does anyone know what code/model number I should be using? Nothing *9865* seems to work.
    Jaleesa_F Posts: 221 ✅ Verified Employee Moderator
    Hello @reefdude!
    Welcome to Community forums! Sorry to hear that it isn't working for you, I am happy to look into this. Was your remote provided by Spectrum?
  • reefdude
    No, I want to use the Samsung universal remote, which worked with my previous Spectrum DVR.
    HT_Greenfield Posts: 536 Contributor
    Depending on what kind of a code cross-reference list you have for the remote, i guess you could try whatever alternatives you may find variously listed under Spectrum or Time Warner or Bright House or Charter.
  • reefdude
    The problem is that all of the devices in the Samdung configuration (Cisco 9800, etc) do not work to control the box properly. This was not an issue with the previous box we had.
    edited November 22
    All i can figure is that the needed specific provider X model X software code isn't in there and if the box is running the Spectrum Guide software, it probably wouldn't be (and might not be, anyway,) in which case i'd alternatively try any model names you could find in there that begin with "Spectrum" or "SP" and see what happens.
