Solution: Fastest Way to Reboot a Cable Receiver Online
Posts: 5,321 Contributor
in TV Equipment
Best is to follow the steps below:
Spectrum Reboot Cable Box Online:
1.) Login to "My Account"
2.) Go to "Services"
3.) Select "TV Tab"
4.) Select your Cable Box or DVR
5.) Spectrum Reboot Cable Box Online
6.) Follow the onscreen prompts.
I was confused with clicking on "Support" instead of Services. "Support" gives you articles and tips for many services, but it doesn't provide a quick reboot prompt of the cable TV equipment. You want to go to "Services" and than select the "TV tab."
I hope this helps!
