Can I block specific sites without going onto another device?
Alexis_A
Alexis_A Posts: 1 Newcomer
I want certain sites blocked over my whole network not just on one device, is there a way I can do that?
  • Ruben_R
    Ruben_R Posts: 106 ✅ Verified Employee Moderator
    You can use the parental control on the router.
  • Community_Help
    Community_Help Posts: 38 ✅ Verified Employee Moderator
    If parental controls do not provide the level of blocking you are looking to achieve, you can also use your own router to set up restrictions. Generally speaking, it is typically easier to block all sites, and then allow access only to approved websites.
