Pixelation and audio dropouts frequent but only on commercials for Spectrum cable
cableuser
cableuser Posts: 2 Novice
edited October 22 in Channels and Programming
I have seen other posts on this forum describing the exact same problem, but they have been closed for some reason (without solution). This problem has occurred for years and on BOTH my TV's in separate rooms and using separate cable boxes. When watching various cable channels, when most but not all Spectrum cable commercial come on the tv, there is constant pixelation of the video and constant audio dropouts throughout the commercial. This problem DOES NOT effect other commercials or the TV programing but JUST the commercials for spectrum cable. Kind of ironic that Spectrum cable boxes cannot view their own commercials, or that Spectrum cable chooses to display their own commercials in some format that is not compatible with their own cable boxes? (cable boxes are branded as Spectrum boxes). Modem has been changed without improvement and since no other company's commercials and the TV programming is not affected, I do not think it likely that there is a problem with the cable signal, but the problem seems to be in the Spectrum commercials themselves perhaps?
    Renee_T Posts: 1,161 ✅ Verified Employee Moderator
    Hello @cableuser
    Welcome to our community. I'm sorry you're experiencing issues with the cable boxes. Exchanging the modem would only resolve the issue if it was happening on the Spectrum TV app, but not the cable boxes themselves. I was able to locate the account using your community registration and while the signal levels look good, the cable boxes do not appear to be fully communicating with us properly which can lead to issues if they aren't updating properly. I would recommend having a technician come out to look into things further. If you'd like us to set up that appointment for you, please let us know and we're happy to get that scheduled.
  • cableuser
    I have had service representatives out and they cannot find anything wrong. This problem has been going on for years, and again, it is ONLY commercials from Spectrum cable that are affected, and nobody else's commercials and no programming.
