How do you download the Spectrum TV Ap on an LG Smart TV?
DM60DM60 Posts: 2
edited September 24 in Spectrum TV App Tips, Resources & FAQs Feb 12, 2018
I cannot find a way to add ap's in LG Content.  If I try the webbrowser it takes forever to load any web address and I cannot get there.  I need to do this today as tomorrow Feb 13 Spectrum goes digital.  If you have step by step instructions that would be great.  Thanks!
    Feb 12, 2018 Accepted Answer
    The Spectrum TV app is only supported on select Samsung smart tvs. I would suggest getting a Roku device to hook up to your LG tv, unless you have an Xbox One which also supports the app.
  • DM60DM60 Posts: 2
    Feb 12, 2018
    Thank you for the quick reply.  Makes sense why I cannot download it.  Would have been nice if the attendant at the Spectrum store told me this rather that jsut say download the ap.
    Feb 12, 2018
    Agreed...their training is sometimes lacking a bit.
    From the website:
  • MsRayeMsRaye Posts: 25,606
    Feb 12, 2018
    the other issue is that you should be using an ethernet connection rather than wireless. The TV's respond a lot faster, on some, you can download an android ap that allows the spectrum one to work.  And some channels allow watching if you have a twc/spectrum id, like the NBC olympics one.
    You would have only had a few basic cable channels and may get more with an antenna on your set... What's your zip code?
