Spectrum blocking university websites
bobackboback Posts: 5
edited August 21 in Internet 2018 Archive Apr 23, 2018
For work I need access to the following websites:
https://sslvpn.mednet.ucla.edu
https://assist.dgsom.ucla.edu/
Since 4/20/18, they've been blocked through my ISP (Spectrum Time Warner). I'm able to access the website fine through my phone (Verizon) and other proxy websites. So the problem seems to be coming from Spectrum. Spectrum denies that block any websites. I'm not sure why else I'm unable to ping or go to the addresses above. I've tried using the IP address as well and get time out errors.
  • karlbeckmankarlbeckman Posts: 2,219 ✭✭✭✭
    Apr 25, 2018 Accepted Answer
    @bobackwrote:
    Always faults after cenic.net
    OK, that's your clue for where to tell UCLA to look for the malfunctioning DNS.  It should be at cenic.net or the next device beyond.  Either way it is outside Spectrum's transport network, and they are not at fault.
  • dstoffadstoffa Posts: 994 ✭✭✭✭
    Apr 23, 2018
    What kind of error message are your getting?
    What DNS are you using?
  • bobackboback Posts: 5
    Apr 23, 2018
    I get time out errors.
    When I had Spectrum tech support try to access the same sites, they couldn't. Are you able to?
    I'm not designating any specific DNS. I get the error hooked up to my cable modem directly.
    Apr 24, 2018
    @bobackwrote:
    ...  edited  ...
    I just tried opening new links to both sites from here in the Great Lakes area and got the expected displays - VPN log-in and the UCLA home page.  If you continue to have issues with the UCLA site, you should be able to get IT support from your employer or from UCLA's IT staff.
    BTW, someone should have pointed out that you DO need a router between the modem LAN jack and your computer, especially when you are trying to run a VPN into the UCLA site.
    Apr 24, 2018
    I can connect using Spectrum internet.
    Apr 25, 2018
    Good morning.
    I can reach both from here on my work network and on our test connection on wireless.
    Are you still having issues?
    Regards,
    Julia R.
    Apr 25, 2018
    A senior Spectrum technician had me run tracert to see what server what timing out. It’s not Spectrum’s fault. After being relayed through spectrum and handed off to university servers, the servers within the university are timing out. Pretty cool diagnostic.
  • Boz1Boz1 Posts: 35
    Apr 25, 2018
    Except myself and several other above can all get to those websites.  If the issue was "the servers within the university are timing out", wouldn't we all have trouble reaching them?  I'm just wondering...
    Apr 25, 2018
    Those of us who can access UCLA are not using the same network route as @boback.  Spectrum has several different IXP locations around the country and the internet routes from each of those handoff sites to UCLA's servers will all be different.  Something in the chain from boback's IXP to UCLA is not passing traffic.
    This is often caused by one DNS that did not process its daily DNS update correctly.  If boback posts his tracert listing, we should be able to see both the last good device name and/or its IP address and the next device downstream which is failing to route properly.
    Apr 25, 2018
    Here's my tracing:
    Tracing route to sslvpn.mednet.ucla.edu [149.142.80.10]
    over a maximum of 30 hops:
      1    <1 ms    <1 ms    <1 ms  192.168.1.1
      2    10 ms     8 ms    10 ms  142.254.182.193
      3    13 ms     7 ms     9 ms  76.167.31.213
      4    15 ms    11 ms    11 ms  agg20.lamrcadq02r.socal.rr.com [72.129.10.130]
      5    21 ms    14 ms    15 ms  agg28.tustcaft01r.socal.rr.com [72.129.9.2]
      6    17 ms    15 ms    15 ms  bu-ether16.tustca4200w-bcr00.tbone.rr.com [66.109.6.64]
      7    18 ms    15 ms    14 ms  be4.clmkohpe01r.midwest.rr.com [107.14.19.37]
      8    42 ms    11 ms    12 ms  0.ae2.pr0.lax00.tbone.rr.com [107.14.19.138]
      9    13 ms    16 ms    10 ms  UniversityCorpforAdvancedInternet.as11164.any2ix.coresite.com [206.72.210.14]
     10    22 ms    12 ms    12 ms  et-1-0-2.0.rtsw.losa.net.internet2.edu [64.57.20.82]
     11    13 ms    15 ms     9 ms  64.57.20.83
     12    14 ms    13 ms    13 ms  dc-lax-agg6--lax-agg8-100ge-#3.cenic.net [137.164.11.34]
     13     *        *        *     Request timed out.
     14    16 ms    12 ms    15 ms  bd11f1.anderson--cr00f2.csb1.ucla.net [169.232.4.4]
     15    13 ms    13 ms    12 ms  cr00f2.csb1--dr00f1.anderson.ucla.net [169.232.4.57]
     16     *        *        *     Request timed out.
     17     *
    Apr 25, 2018
    Apr 26, 2018
    Thanks for the explanation, karlbeckman.
  • tech-sgttech-sgt Posts: 1
    Apr 30, 2018
    I can hit both of those with no problems from my spectrum home network.
