New Modem Router Brings Repeated Dropped Service
TeamCowanTeamCowan Posts: 4
edited August 21 in Internet 2019 Archive Mar 17, 2019
First time posting but was searching Google and found this community, hopeful for help finding and addressing root cause of frequent internet outages in my home.
I did search here for similar issues and found nothing actionable other than I may have to have a tech come out. I’m also going to follow the “DATA TO POST TO GET HELP FROM THE COMMUNITY” page and paste where I can from my modem Admin login, so please excuse formatting, etc.
Thanks in advance.
-Your location. city, state, zip.: Moreno Valley, CA 92557
-Single or multi family complex.: Single
-Services you get from TWC: internet
-Make and model of modem: TP-Link Archer CR500 (is a model router)
-Make and model of router(s): TP-Link Archer CR500 (is a model router)
-Firmware level in modem (or, post modem page):
Standard Specification Compliant DOCSIS 3.0
Hardware Version V1.0
Software Version v1.0.0 Build 20160829 Rel249990
CM certificate Installed
-Confirm modem is Online or report otherwise. Login to your twc account and click on troubleshoot. Confirm modem with correct serial/mac has a green dot. : Confirmed following these steps
-What are your purchased speeds?: 100 DL/10UL
-What are results from Spectrum speed test. down, up, ping, jitter?: down= 117, up= 11.7, ping= 18ms, jitter= 1ms
-List symptoms using a wired (not wireless) connection with date and time and any repeating pattern: unknown, none of home’s connected devises use a wired connection except for the ADT Security “Pulse Gateway” and it’s passive/just sits there/I’m not sure if I would know if there was an issue?
-Modem's signal, downstream and upstream, and event log pages.:
Downstream Bonded Channels:
Channel Status Modulation Channel ID Frequency Power SNR
1 Locked QAM256 7 555000000 Hz -1.5 dBmV 40.2 dB
2 Locked QAM256 3 531000000 Hz -1.6 dBmV 40.2 dB
3 Locked QAM256 4 537000000 Hz -1.0 dBmV 40.6 dB
4 Locked QAM256 6 549000000 Hz -0.8 dBmV 41.0 dB
5 Locked QAM256 8 561000000 Hz -0.7 dBmV 41.1 dB
6 Locked QAM256 9 567000000 Hz -1.5 dBmV 40.3 dB
7 Locked QAM256 10 573000000 Hz -0.6 dBmV 41.4 dB
8 Locked QAM256 11 579000000 Hz -1.3 dBmV 40.4 dB
9 Locked QAM256 12 585000000 Hz -0.6 dBmV 41.4 dB
10 Locked QAM256 13 591000000 Hz -1.3 dBmV 40.4 dB
11 Locked QAM256 15 603000000 Hz -1.1 dBmV 41.0 dB
12 Locked QAM256 17 615000000 Hz -1.0 dBmV 41.0 dB
13 Locked QAM256 18 621000000 Hz -0.9 dBmV 41.3 dB
14 Locked QAM256 19 627000000 Hz -1.0 dBmV 41.3 dB
15 Locked QAM256 20 633000000 Hz -1.0 dBmV 41.1 dB
16 Locked QAM256 21 639000000 Hz -1.0 dBmV 41.1 dB
Upstream Bonded Channels:
Channel Status Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 74 5120 ksym/sec 24000000 Hz 40.3 dBmV
2 Locked ATDMA 73 5120 ksym/sec 17600000 Hz 39.8 dBmV
3 Locked ATDMA 75 5120 ksym/sec 30400000 Hz 40.8 dBmV
4 Locked ATDMA 76 5120 ksym/sec 36800000 Hz 40.8 dBmV
Event log (lost connectivity last night so I reset the router before going to bed):
Time Priority Description
Sun Mar 17 04:58:35 2019 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.1;CM-VER=3.0;
Sun Mar 17 04:58:35 2019 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.1;CM-VER=3.0;
Sun Mar 17 12:58:19 2019 Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
Sun Mar 17 12:58:12 2019 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.0;CM-VER=3.0;
Sun Mar 17 12:58:02 2019 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.1;CM-VER=3.0;
Sun Mar 17 12:58:02 2019 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.1;CM-VER=3.0;
Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=xx.xx.xx:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.0;CM-VER=...
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4
Sun Mar 17 04:57:09 2019 Critical (3) Resetting the cable modem due to docsDevResetNow
Mon Mar 11 18:51:26 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx.xx.xx:36:b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;...
Sun Feb 03 00:25:39 2019 Critical (3) Resetting the cable modem due to docsDevResetNow
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=xx.xx.xx.b7:1b;CMTS-MAC=00:01:5c:6a:22:4f;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx.xx.xx:36:b7:1b;CMTS-MAC=00:00:00:00...
-Description of your cable wiring from street and throughout house, include splitters, devices, cable type (rg6, rg59) and age, etc. and specifically the where the modem attaches.: Can’t say I guess, I just have the modem router attached to the wall via coax cable that we used with our prior modem. All the wiring I see looks like new (no corrosion, fraying, kinks, etc.)
-Description of ethernet network from modem’s ethernet port to router(s) and to any additional devices including cable type, e.g., cat5, cat5e, cat6, etc.: Also unsure how to answer this, other than to say that the modem router is one unit, so no auxiliary router is attached. The only thing connected to the unit via cat5 is the ADT Security “Pulse gateway”. The other 5-10 connected devices using internet daily in my home all connect wirelessly
-Any recent or coincident changes or upgrades to your system, or any neighborhood changes.: About six weeks I got fed up with “slow” internet service relative to what I was paying (I had no idea what internet package I had, just that I was paying $60/mo for <30mbs download speed as tested by SpeedTest site). I called TWC CS and eventually discovered that my existing modem router wasn’t dual-band so I wasn’t getting the benefit of the 5GHz service. Using a list provide by TWC (or is it Spectrum now?) I went searching for a new modem router and purchased the TP-Link Archer CR500. It’s worth nothing that we lived in this home with the same internet package and previous modem router for 3.5 years and I never recall the internet “dropping” the way it has since purchasing this new TP-Link unit.
-Run pathping (windows command) targeting a site that demonstrates problem, preferably one that is pingable, like rr.com. If pathping is not available as command execute tracert. (Linux command istraceroute): No pattern found in what site(s) are being accessed when signal drops
-Mention if you only have connection problems while streaming movies/other or playing games.: We stream movies often through AppleTV but I haven’t determined pattern of the signal dropping during/not during streaming, etc. I can say that it has dropped while the TV/AppleTV was entirely of. We also don’t use connected gaming platforms.
- Are any background tasks running that upload or download data automatically, e.g., backup programs, torrent client, file/photo/music sync, auto program/app update, etc.?: Nothing known/intentional. Maybe some functionality of our connected ADT Security system or Apple iPhones/iPads periodically syncing to iCloud.
Man, lot of typing there. Hope that’s enough to get to the bottom of this!
Thanks again.
-Rex
Accepted Answers
    Mar 18, 2019 Accepted Answer
    The changes suggested by TP-Link are an effort to minimize wifi interference. On the 2.4 band, channels 1, 6, and 11 don't overlap and tend to have less interference but also the majority of users (aka neighbors) are on 1,6, or 11, increasing potential interference. On the 5 band, the high channels are less used.  If devices on one band drop but the other band is still connected it's a wifi issue for sure.
    If your logs are showing frequent T3 or T4 timeouts then that tends to be a physical issue with the coax delivery and would impact wired and wireless. That would require techs to verify nothing in your home is causing the problem, then escalate it up the chain to the crews that maintain the main lines to find squirrel chewed lines, water damage, failing amps, nodes, etc.
  • TeamCowanTeamCowan Posts: 4
    Mar 26, 2019 Accepted Answer
    Been a week since I made the changes recommended by TP-Link and I’ve had no further issues with interrupted service in my home.
    I appreciate this group’s help and will update here if issues resume, partly to continue seeking help to resolve but also in the event someone is having the same problems after me, stumbles upon this forum like I did and is able to use the info to self-diagnose and resolve.
    -Rex
    Mar 18, 2019
    How often do your wireless devices drop connections? When drops occur do all devices go offline at the same time? Does your ethernet connected security system go down?
    I'm asking this to eliminate wifi as the culprit. The best way to do that is to ethernet connect whatever you can and monitor for drops. If the wired devices stay connected then the issue is wif interference or weak signals. If the wired devices also drop then the issue is likely a loose connector or damaged coax somewhere. If you've checked everything from the modem to the wall jack and it's all good, then the problem is somewhere from the wall jack back to the demarc, pedestal at the street, overhead lines, etc.
    Mar 18, 2019
    First, I appreciate any effort to help with this, especially one so timely. Thank you.
    We experience lost connectivity 2-3 times a week but when I’ve gone into event logs, similar instances also seem to be occurring in the middle of the night when we wouldn’t notice. Unfortunately my unit doesn’t appear to log more than a few days of events so it’s difficult to do any meaningful trend analysis on it.
    Yes, when it drops all devices connected wirelessly are affected. What I’ve not thought of until right now though is whether it could be related to one or the other of the bands? For example, my and my wife’s iPhones and kids’ iPads are connected to the 5GHz band but our Wemo devices are connected to the 2.4GHz band; when our phones drop I haven’t thought to check the Wemo switches to see if they also drop. Maybe this is irrelevant but I’ll check next time.
    Also, the only wired connection to the modem router is the ADT Security box and, until you asked, I’ve not thought to look at it when our wireless devices drop to see if it has also lost connectivity - I’ll check this next time also.
    To your question of cables and connections, I’m as confident as I can be that cables are in good condition from the unit to the wall and I tightened all connections I could access having read in another troubleshooting effort where coax couplings were suggested to be made “slightly more than hand tight” due to opportunity for interference or “leakage”. Figured easy enough to do if that could be a contributing factor.
    To cast a wide net, the morning I posted the original request for help here I also sent a similar request to TP-Link Customer Service and this is what I got back this morning:
    Dear Rex,
    Thank you very much for requesting information about our product.
    Sincerely sorry for the trouble caused.
    Could you please follow the guidance below to change the channel and channel width on the modem router and see if it helps?
    1).Please connect a PC to the modem router,and login to 192.168.1.1 or tplinkmodem.net.
    2).Please click on Advanced->Wireless 2.4G->Basic Settings,change the channel width to 20MHz and change the channel to 1,6 or 11.
    Then,please click on Advanced->Wireless 5G->Basic Settings,and change the channel width to 20MHz,and change the channel to 149-165.
    I don’t know what the significance of those changes are but I made them as suggested and we’ll see what happens. Kind of curious though to know what they saw in the data (same I posted in original request here) that led them to request those setting changes?
    Mar 19, 2019
    Interesting, thanks for that insight.
    I’ll update this thread on any changes and close it out ASAP!
