Questions About New Spectrum Guide Remotes?
SatchSatch Posts: 3,716 helper
edited August 27 in Watch TV 2019 Archive Aug 07, 2019
 I have been getting a lot of questions from Spectrum Customers about the new remotes being given out with the World Boxes.  For reference, I am referring to the remote below.  Answers from the community to the following questions are needed by many:
1.) Where is the button on the new Spectrum Remote that Starts Over a program if Start Over is offered on the channel in question?
2.) How do you delete a series using this pictured remote in Spectrum Guide?
Accepted Answers
  • adiladubadiladub Posts: 5
    Aug 09, 2019 Accepted Answer
    Here's one way to cancel a series using this remote:
    1. Go to My DVR either through the Menu or by hitting the DVR button.
    2. Scroll down to Scheduled
    3.  Scroll over and select the series you want to cancel
    4.  Scroll over to Series Info
    5. Hit Cancel Recording
    6. Confirm that you want to Cancel Recording
    This will cancel all scheduled and future recordings of the series. Not the most intuitive process but it works.
  • SatchSatch Posts: 3,716 helper
    Aug 14, 2019 Accepted Answer
    Update:
    There is a double-edged sword using this method:
    1.) If there are more episodes of the series in the system database forthcoming, and can be searched for, using New Spectrum Guide  these steps will work.
    HOWEVER:
    2.) If there are no more scheduled episodes in the database of the series selected to be deleted, users will receive an error message
    Spectrum is working on a fix for #2 for The New Spectrum Guide in a future software update. (Confirmed via @Ask Spectrum @ Twitter.)
  • James_MJames_M Posts: 2,269 ADMIN
    Aug 08, 2019
    Start Over and some other features are not available on every set top box or with every guide.  For the most accurate information, we would need to know the guide version and equipment being used.   If customers are contacting you directly, then I would suggest you direct them a support channel for further assistance.
    I also included a link to Spectrum Remote Control: URC 1160 that may answer some additional questions.
