Signal Diagnosis
mrsteveamrstevea Posts: 7
edited August 21 in Internet 2019 Archive Aug 16, 2019
About 5 days ago, I recently swapped our modem and received the DOCSIS 3.1 Ubee E31U2V1 (we have telephone service)  since it looked out or old modem (Arris TG1672G) was on its last legs and had to be restarted frequently or it was losing connection more often. Additonally, we are using a google wifi with 3  of those pucks as a mesh network (using MOCA for ethernet backhaul).
Anyways,  our connection has been fine now for the past few days, but with some choppiness on skype/discord calls at times, although that could be due to some other issues.
While it is a pain to get access to, I took a look at the modem's signal page, Everything seems to be fine and dandy except for the upstream which is a little high according to the reference here in the forums. But this might also be due to the fact that we live in a hilly environment, where even our cell service can be horrid. Though even another reason that our internet should be consistent as possible.
Anways, I just want to know what your thoughts are of our signals, and if we should call a Spectrum Tech about the upstream or any other signs of concerns.
Thanks.
  • RAIST5150RAIST5150 Posts: 797 ✭✭✭✭
    Aug 16, 2019 Accepted Answer
    Modem is essentially screaming to be heard... and about to give up and reboot. Noise may be creeping into the return path. Could be a failing power supply/amp/splitter/etc. that a tech will need to rule out.
    Otherwise, look for things like compromised shielding, loose/corroded connections, sections of cable that may be regularly exposed to water, high heat, etc.. Also want to avoid sharp bends... ideally no sharper than about what it takes to wrap around a 2-liter soda bottle.
    If you can see where the wire comes in and connects to the in-house cabling, that splitter/coupling point should have grounding wire that runs directly to the nearest grounding post from the electric company (nothing fancy... may just be a simple metal stake in the ground that wires are bolted to). Make sure that wire has a clean and tight connection at both ends.
    As @reds91185 was pointing out, don't want any open cables in the house. Each connected cable should should have a device connected or have a termination cap on it. No more splits in play than necessary to serve the devices in use... but don't just disconnect a cable from a splitter, as that can be just as bad (if not worse) then leaving an open cable connected. Ideally you would want to switch to a smaller splitter (x4 to x2). If you can't switch to a smalller splitter, then the unneeded port should have at least a few feet of cable with a termination cap on it to reduce the risk of weird signal reflection feeding back.
  • mrsteveamrstevea Posts: 7
    Aug 16, 2019
    CM Downstream Channel Info
    Channel
    Lock Status
    Channel Type
    Channel ID
    Frequency
    Width
    Power
    SNR
    Modulation Profile ID
    Correctables
    Uncorrectables
    Locked
    SC-QAM Downstream
    31
    705000000 Hz
    6000000 Hz
    1.3 dBmV
    43.5 dB
    QAM256
    2
    Locked
    SC-QAM Downstream
    693000000 Hz
    6000000 Hz
    1.2 dBmV
    43.3 dB
    QAM256
    3
    Locked
    SC-QAM Downstream
    2
    525000000 Hz
    6000000 Hz
    1.1 dBmV
    43.7 dB
    QAM256
    4
    Locked
    SC-QAM Downstream
    3
    531000000 Hz
    6000000 Hz
    1.1 dBmV
    43.5 dB
    QAM256
    5
    Locked
    SC-QAM Downstream
    4
    537000000 Hz
    6000000 Hz
    1.3 dBmV
    43.7 dB
    QAM256
    6
    Locked
    SC-QAM Downstream
    5
    543000000 Hz
    6000000 Hz
    1.1 dBmV
    43.7 dB
    QAM256
    7
    Locked
    SC-QAM Downstream
    6
    549000000 Hz
    6000000 Hz
    1.1 dBmV
    43.6 dB
    QAM256
    8
    Locked
    SC-QAM Downstream
    7
    555000000 Hz
    6000000 Hz
    1.2 dBmV
    43.7 dB
    QAM256
    9
    Locked
    SC-QAM Downstream
    8
    561000000 Hz
    6000000 Hz
    1.1 dBmV
    43.7 dB
    QAM256
    10
    Locked
    SC-QAM Downstream
    9
    567000000 Hz
    6000000 Hz
    1.3 dBmV
    43.8 dB
    QAM256
    11
    Locked
    SC-QAM Downstream
    10
    573000000 Hz
    6000000 Hz
    1.2 dBmV
    43.6 dB
    QAM256
    12
    Locked
    SC-QAM Downstream
    11
    579000000 Hz
    6000000 Hz
    1.3 dBmV
    43.8 dB
    QAM256
    13
    Locked
    SC-QAM Downstream
    12
    585000000 Hz
    6000000 Hz
    1.1 dBmV
    43.6 dB
    QAM256
    14
    Locked
    SC-QAM Downstream
    13
    591000000 Hz
    6000000 Hz
    1.3 dBmV
    43.5 dB
    QAM256
    15
    Locked
    SC-QAM Downstream
    14
    597000000 Hz
    6000000 Hz
    1.6 dBmV
    43.7 dB
    QAM256
    16
    Locked
    SC-QAM Downstream
    15
    603000000 Hz
    6000000 Hz
    1.5 dBmV
    43.7 dB
    QAM256
    17
    Locked
    SC-QAM Downstream
    16
    609000000 Hz
    6000000 Hz
    1.4 dBmV
    43.6 dB
    QAM256
    18
    Locked
    SC-QAM Downstream
    17
    615000000 Hz
    6000000 Hz
    1.5 dBmV
    43.7 dB
    QAM256
    19
    Locked
    SC-QAM Downstream
    18
    621000000 Hz
    6000000 Hz
    1.5 dBmV
    43.6 dB
    QAM256
    20
    Locked
    SC-QAM Downstream
    19
    627000000 Hz
    6000000 Hz
    1.8 dBmV
    43.5 dB
    QAM256
    21
    Locked
    SC-QAM Downstream
    20
    633000000 Hz
    6000000 Hz
    1.8 dBmV
    43.8 dB
    QAM256
    22
    Locked
    SC-QAM Downstream
    21
    639000000 Hz
    6000000 Hz
    1.8 dBmV
    43.8 dB
    QAM256
    23
    Locked
    SC-QAM Downstream
    22
    645000000 Hz
    6000000 Hz
    1.9 dBmV
    43.3 dB
    QAM256
    24
    Locked
    SC-QAM Downstream
    23
    651000000 Hz
    6000000 Hz
    2.2 dBmV
    43.9 dB
    QAM256
    25
    Locked
    SC-QAM Downstream
    24
    657000000 Hz
    6000000 Hz
    1.9 dBmV
    43.9 dB
    QAM256
    26
    Locked
    SC-QAM Downstream
    25
    663000000 Hz
    6000000 Hz
    1.6 dBmV
    43.3 dB
    QAM256
    27
    Locked
    SC-QAM Downstream
    26
    669000000 Hz
    6000000 Hz
    1.5 dBmV
    43.3 dB
    QAM256
    28
    Locked
    SC-QAM Downstream
    27
    675000000 Hz
    6000000 Hz
    1.3 dBmV
    42.3 dB
    QAM256
    29
    Locked
    SC-QAM Downstream
    28
    681000000 Hz
    6000000 Hz
    1.3 dBmV
    43.3 dB
    QAM256
    30
    Locked
    SC-QAM Downstream
    29
    687000000 Hz
    6000000 Hz
    1.3 dBmV
    43.3 dB
    QAM256
    31
    Locked
    SC-QAM Downstream
    30
    699000000 Hz
    6000000 Hz
    1 dBmV
    43.3 dB
    QAM256
    32
    Locked
    OFDM Downstream
    33
    380000000 Hz
    94000 kHz
    2.8 dBmV
    43.0 dB
    0 1 2
    Channel
    Lock Status
    Channel Type
    Channel ID
    Frequency
    Width
    Power
    Modulation/Profile ID
    Locked
    ATDMA
    57
    17600000 Hz
    6400000 Hz
    50.5 dBmV
    2
    2
    Locked
    ATDMA
    58
    24000000 Hz
    6400000 Hz
    51 dBmV
    2
    3
    Locked
    ATDMA
    59
    30400000 Hz
    6400000 Hz
    51.8 dBmV
    2
    4
    Locked
    ATDMA
    60
    36800000 Hz
    6400000 Hz
    52.3 dBmV
    2
  • rocketjetzrocketjetz Posts: 135 ✭✭✭✭
    Aug 16, 2019
    Your downstream  Power levels range from  1 dBMv to 2.8 dBMv.... This looks good.
    Your downstream SNR range from 43.0 to 43.9.....which is excellent
    your Upstream Power levels are borderline high.
    https://forums.timewarnercable.com/t5/Connectivity/FYI-basics-of-signal-power-level/m-p/116692#M37639
    Aug 16, 2019
    Yeah those upstream levels are right on the edge. Any slight change in temperature, wind, or just regular interference can push those too high a cause a problem.
    Do you have multiple splitters or any unused legs off a splitter that can be eliminated?
  • karlbeckmankarlbeckman Posts: 2,223 ✭✭✭✭
    Aug 17, 2019
    You definitely have a line loss issue with the upstream side of your connection.  And if you don't seriously need Gigabit internet, I would tell Spectrum to reset it down to 300 Mbps and reduce your monthly billing total.  Asking for a higher speed doesn't fix any existing line issues.
    Aug 20, 2019
    So I noticed the splitter (3 way) connecting to my modem was the 7.0 db, and switched that coax to the 3.5.
    All the other coax that were connected to the splitter was switched vice versa. The modem should usually always be on the port that recieves the least amount of signal loss, so it was a bit weird that the technician did this.
    It did turn my upstream levels from good to 'average or decent/',  but the downstream levels  is more managable. I'll keep monitoring my modem signals for the next couple weeks, but this should be fine and dandy for now.
    Aug 20, 2019
    Channel
    Lock Status
    Channel Type
    Channel ID
    Frequency
    Width
    Power
    SNR
    Correctables
    Uncorrectables
    Locked
    SC-QAM Downstream
    30
    699000000 Hz
    6000000 Hz
    4.5 dBmV
    43.1 dB
    QAM256
    2
    Locked
    SC-QAM Downstream
    693000000 Hz
    6000000 Hz
    4.8 dBmV
    43.2 dB
    QAM256
    3
    Locked
    SC-QAM Downstream
    2
    525000000 Hz
    6000000 Hz
    4.7 dBmV
    43.5 dB
    QAM256
    4
    Locked
    SC-QAM Downstream
    3
    531000000 Hz
    6000000 Hz
    4.8 dBmV
    43.5 dB
    QAM256
    5
    Locked
    SC-QAM Downstream
    4
    537000000 Hz
    6000000 Hz
    4.8 dBmV
    43.6 dB
    QAM256
    6
    Locked
    SC-QAM Downstream
    5
    543000000 Hz
    6000000 Hz
    4.6 dBmV
    43.5 dB
    QAM256
    7
    Locked
    SC-QAM Downstream
    6
    549000000 Hz
    6000000 Hz
    4.6 dBmV
    43.4 dB
    QAM256
    8
    Locked
    SC-QAM Downstream
    7
    555000000 Hz
    6000000 Hz
    4.7 dBmV
    43.2 dB
    QAM256
    9
    Locked
    SC-QAM Downstream
    8
    561000000 Hz
    6000000 Hz
    4.6 dBmV
    43.5 dB
    QAM256
    10
    Locked
    SC-QAM Downstream
    9
    567000000 Hz
    6000000 Hz
    4.9 dBmV
    43.3 dB
    QAM256
    11
    Locked
    SC-QAM Downstream
    10
    573000000 Hz
    6000000 Hz
    4.9 dBmV
    43.6 dB
    QAM256
    12
    Locked
    SC-QAM Downstream
    11
    579000000 Hz
    6000000 Hz
    4.7 dBmV
    43.4 dB
    QAM256
    13
    Locked
    SC-QAM Downstream
    12
    585000000 Hz
    6000000 Hz
    4.7 dBmV
    43.4 dB
    QAM256
    14
    Locked
    SC-QAM Downstream
    13
    591000000 Hz
    6000000 Hz
    5.1 dBmV
    43.4 dB
    QAM256
    15
    Locked
    SC-QAM Downstream
    14
    597000000 Hz
    6000000 Hz
    5.1 dBmV
    43.5 dB
    QAM256
    16
    Locked
    SC-QAM Downstream
    15
    603000000 Hz
    6000000 Hz
    5 dBmV
    43.5 dB
    QAM256
    17
    Locked
    SC-QAM Downstream
    16
    609000000 Hz
    6000000 Hz
    5 dBmV
    43.1 dB
    QAM256
    18
    Locked
    SC-QAM Downstream
    17
    615000000 Hz
    6000000 Hz
    5 dBmV
    43.5 dB
    QAM256
    19
    Locked
    SC-QAM Downstream
    18
    621000000 Hz
    6000000 Hz
    5.1 dBmV
    43.1 dB
    QAM256
    20
    Locked
    SC-QAM Downstream
    19
    627000000 Hz
    6000000 Hz
    5.5 dBmV
    43.5 dB
    QAM256
    21
    Locked
    SC-QAM Downstream
    20
    633000000 Hz
    6000000 Hz
    5.5 dBmV
    43.6 dB
    QAM256
    22
    Locked
    SC-QAM Downstream
    21
    639000000 Hz
    6000000 Hz
    5.1 dBmV
    43.5 dB
    QAM256
    23
    Locked
    SC-QAM Downstream
    22
    645000000 Hz
    6000000 Hz
    5.5 dBmV
    43.7 dB
    QAM256
    24
    Locked
    SC-QAM Downstream
    23
    651000000 Hz
    6000000 Hz
    5.8 dBmV
    43.8 dB
    QAM256
    25
    Locked
    SC-QAM Downstream
    24
    657000000 Hz
    6000000 Hz
    5.3 dBmV
    43.4 dB
    QAM256
    26
    Locked
    SC-QAM Downstream
    25
    663000000 Hz
    6000000 Hz
    5.3 dBmV
    43.1 dB
    QAM256
    27
    Locked
    SC-QAM Downstream
    26
    669000000 Hz
    6000000 Hz
    5.2 dBmV
    43.2 dB
    QAM256
    28
    Locked
    SC-QAM Downstream
    27
    675000000 Hz
    6000000 Hz
    4.9 dBmV
    42.6 dB
    QAM256
    29
    Locked
    SC-QAM Downstream
    28
    681000000 Hz
    6000000 Hz
    4.9 dBmV
    43.1 dB
    QAM256
    30
    Locked
    SC-QAM Downstream
    29
    687000000 Hz
    6000000 Hz
    4.9 dBmV
    43.1 dB
    QAM256
    31
    Locked
    SC-QAM Downstream
    31
    705000000 Hz
    6000000 Hz
    5.1 dBmV
    43.4 dB
    QAM256
    32
    Locked
    OFDM Downstream
    33
    380000000 Hz
    94000 kHz
    6.2 dBmV
    43.0 dB
    0 1 2
    Aug 20, 2019
    CM Upstream Channel Info
    Channel
    Lock Status
    Channel Type
    Channel ID
    Frequency
    Width
    Power
    Locked
    ATDMA
    57
    17600000 Hz
    6400000 Hz
    47 dBmV
    2
    2
    Locked
    ATDMA
    58
    24000000 Hz
    6400000 Hz
    47.8 dBmV
    2
    3
    Locked
    ATDMA
    59
    30400000 Hz
    6400000 Hz
    48.8 dBmV
    2
    4
    Locked
    ATDMA
    60
    36800000 Hz
    6400000 Hz
    49 dBmV
    2
    Aug 20, 2019
    Those upstream power levels definitely look better now. Weird that the tech put the modem on the highest loss leg of the splitter...he should have known better.
    My own upstream levels are usually in this range of 47-49.5 and I don't have any problems...I'm using the same modem.
