On Demand/Channel search no longer available
douglas9douglas9 Posts: 15 ✭✭✭
The On Demand search function has become pretty much useless....With the new changes you can no longer search individual channels (networks) for On Demand programming.....Any chance channel search capability will return to On Demand?
  • SatchSatch Posts: 3,821 helper
    Sep 17, 2020
    Several possibilities here:
    1.) The search is down for maintenance or updates. When did this start?
    2.) The remotes should have an On Demand button that you can press to get to On Demand Channels.
    3.) What cable box and guide do you have?
  • douglas9douglas9 Posts: 15 ✭✭✭
    Sep 17, 2020
    Started maybe 9.15.20....worked fine day before called Spectrum support.....and they too were baffled...and couldn't find channel(network) search function for On Demand...informed they couldn't help me....
    1. .Doesn't work...no channel listing..
    Sep 18, 2020
    Rebooting did the trick. The channel(network) option has returned to the menu and able to search On Demand networks. Thank you for your time, patience and efforts.
