**NEW** Advanced Search Options
We recently added advanced search options to make it easier to locate posts on the community.
Welcome to the Community!
What happened to the DVR section in the Spectrum TV App?
usrusr Posts: 6 ✭✭✭
I don't see the DVR section any longer. As a result I cannot delete recordings or see available space on my DVR.
  • SatchSatch Posts: 4,151 ✭✭✭✭
    edited October 2020 Oct 16, 2020
    What is the make and model of your DVR? Any recent changes to your services or your account to note? Android Version number and/or OS? Are you up-to-date with your Android? Give your city, state, and zip code please.
  • usrusr Posts: 6 ✭✭✭
    Oct 16, 2020
    Hi Satch,
    Thanks for reaching out. I just noticed that my phone shows the DVR section but my tablet does not.
    Phone is OS v9 but the tablet is v5.0.2. I guess that could explain the difference but the App version is the same: 8.9.0
    Oct 17, 2020
    Hi @usr ,
    We had a thread on this topic in the past, see if the steps in this thread work for you:
    edited October 2020 Oct 17, 2020
    In addition to the post above, this section might help as well
    See @James_M 's instructions in both responses to fix this. (Review the thread above, and the previous thread about that for his responses.) Let us know if these steps do not work and than a moderator can investigate deeper if needed.
    Oct 17, 2020
    Thank you, Satch.
