Is My SB8200 Operating Normal?
johnd3johnd3 Posts: 2 ✭✭
in Connectivity Oct 18, 2020
Hi. I have the 400Mbps plan and just recently got a SB8200 hardware rev 6 (firmware AB01.01.009.36.02_022720_183.0A.NSH). I am getting a lot of corrected error on channel 29 with locked status but showing Modulation as Other instead of QAM256. Nothing out of ordinary from the event log. Is this normal?
Startup Procedure
Procedure  Status Comment
Acquire Downstream Channel 488000000 Hz  Locked
Connectivity State OK Operational
Boot State OK Operational
Configuration File OK
Security  Enabled BPI+
DOCSIS Network Access Enabled  Allowed
Downstream Bonded Channels
Channel ID Lock Status Modulation Frequency  Power  SNR/MER Corrected  Uncorrectables
29 Locked Other  488000000 Hz  0.6 dBmV  42.2 dB 1440907546 0
1  Locked QAM256 579000000 Hz  0.5 dBmV  43.6 dB 0  0
2  Locked QAM256 585000000 Hz  0.6 dBmV  43.5 dB 0  0
3  Locked QAM256 591000000 Hz  0.6 dBmV  43.6 dB 0  0
4  Locked QAM256 597000000 Hz  0.9 dBmV  43.6 dB 0  0
5  Locked QAM256 603000000 Hz  1.1 dBmV  43.6 dB 0  0
6  Locked QAM256 609000000 Hz  0.9 dBmV  43.5 dB 0  0
7  Locked QAM256 615000000 Hz  0.8 dBmV  43.4 dB 0  0
8  Locked QAM256 621000000 Hz  0.7 dBmV  43.4 dB 0  0
9  Locked QAM256 627000000 Hz  0.7 dBmV  43.3 dB 0  0
10 Locked QAM256 633000000 Hz  0.8 dBmV  43.4 dB 0  0
11 Locked QAM256 639000000 Hz  0.6 dBmV  43.3 dB 0  0
12 Locked QAM256 645000000 Hz  0.8 dBmV  43.5 dB 0  0
13 Locked QAM256 651000000 Hz  0.7 dBmV  43.3 dB 0  0
14 Locked QAM256 657000000 Hz  0.7 dBmV  43.4 dB 0  0
15 Locked QAM256 663000000 Hz  0.5 dBmV  43.3 dB 0  0
16 Locked QAM256 669000000 Hz  0.5 dBmV  43.2 dB 0  0
17 Locked QAM256 675000000 Hz  0.4 dBmV  42.1 dB 0  0
18 Locked QAM256 681000000 Hz  0.3 dBmV  43.0 dB 0  0
19 Locked QAM256 687000000 Hz  0.1 dBmV  42.9 dB 0  0
20 Locked QAM256 693000000 Hz  -0.1 dBmV  42.9 dB 0  0
21 Locked QAM256 699000000 Hz  0.1 dBmV  43.1 dB 79 24
22 Locked QAM256 705000000 Hz  0.1 dBmV  43.0 dB 21 0
23 Locked QAM256 711000000 Hz  -0.3 dBmV  42.9 dB 0  0
24 Locked QAM256 717000000 Hz  -0.1 dBmV  42.9 dB 0  0
25 Locked QAM256 723000000 Hz  -0.2 dBmV  42.9 dB 0  0
26 Locked QAM256 729000000 Hz  -0.5 dBmV  42.7 dB 0  0
27 Locked QAM256 735000000 Hz  -0.5 dBmV  42.7 dB 0  0
28 Locked QAM256 741000000 Hz  -0.3 dBmV  42.9 dB 0  0
30 Locked QAM256 747000000 Hz  -0.5 dBmV  42.8 dB 0  0
31 Locked QAM256 753000000 Hz  -0.6 dBmV  42.7 dB 0  0
32 Locked QAM256 759000000 Hz  -1.1 dBmV  42.5 dB 0  0
Upstream Bonded Channels
Channel Channel ID Lock Status US Channel Type Frequency  Width  Power
1  2  Locked SC-QAM Upstream 24200000 Hz 6400000 Hz 52.0 dBmV
2  3  Locked SC-QAM Upstream 30600000 Hz 6400000 Hz 51.0 dBmV
3  4  Locked SC-QAM Upstream 37000000 Hz 6400000 Hz 51.0 dBmV
4  1  Locked OFDM Upstream  2800000 Hz 13900000 Hz 50.0 dBmV
  • misterjmisterj Posts: 118 ✭✭✭✭
    Oct 18, 2020
    johnd3, I have the same thing on my SB8200. I suspect that is an OFDM channel. I recommend you open a support ticket and ask Arris what that is. Is you Down Stream LED on the front BLUE? If so, that means it is OFDM. I think the modem is great, but their understanding is poor and the statistics are not good. Statistics are much easier to read if pasted as as a screenshot not a copy. Thanks and enjoy, John.
  • johnd3johnd3 Posts: 2 ✭✭
    Oct 18, 2020
    Yes. the front panel is blue so my understanding is it is running 3.1. But the "corrected" error keeps going up. since positing 8hs ago it is now at 4127809677.
    Oct 18, 2020
    Mine too, johnd3. Now it is 19960873. Please ask Arris. Enjoy, John.
