Apple Store, iTunes connectivity problems
mjl2333mjl2333 Posts: 2
edited August 5 in Internet 2021 Archive Apr 26, 2021
Hello-I've been experiencing connectivity problems with apple sites, peloton and Roblox since this afternoon. All these sites can be reached via a cellular connection but will not work over wifi. I've rebooted multiple times, checked firmware and connection speeds with no issue found. Other websites and streaming television is working fine. Can you help?
  • James_MJames_M Posts: 3,069 ADMIN
    edited April 27 Apr 27, 2021
    Restarting the modem usually resolves most issues like this one. You may also need to clear the cache and browsing history. Let us know if you are still seeing an issue.
  • karlbeckmankarlbeckman Posts: 2,277 ✭✭✭✭
    Apr 29, 2021
    Also let's rule out any WiF interference issues. Try connecting your computer to the router using a hard-wired CAT-5e ethernet cable, which will support up to 1 Gigabit service. If you can then connect to the listed hosts, the problem is with your WiFi environment or setup parameters.
