Changing the internal IP scheme
MJTIIIMJTIII Posts: 2 Spectator
in Home Networking Oct 08, 2021
Hi
I just go a new Sagemcom SAC2V2S router. It is on an internal IP scheme of 192.168.1.x. Is there a way to change that? I have the mobile app (where i was able to change the wifi SSID and pw) but can't find anyplace to change the IP scheme/DHCP. I would like to change it so it doesnt conflict with another network i remote into.
  • Paul_BPaul_B Posts: 420 Moderator
    Oct 08, 2021
    Thank you for reaching out to us. I checked into this for you and unfortunately, there is no way to modify the internal IP scheme on these routers. I apologize.
    I can go ahead and submit feedback that this is a feature that you would like to see implemented.
    Paul_B
  • MJTIIIMJTIII Posts: 2 Spectator
    Oct 08, 2021
    Hi Paul
    Thanks for the reply. Yes, please submit feedback. That would be a helpful feature.
    Mike
