what are the Spectrum IPv6 connection type settings
howarthjwhowarthjw Posts: 3 Spectator
in Connectivity Nov 13, 2021
I am trying to enable IPv6 on a TP Link AX21 wireless router and have gotten IPv6 working once but haven't been able to repeat this trick. Does anyone know the technical settings used for Spectrum's IPv6 implementation? Specifically, do they use DCHPv6 or SLAAC for setting the IPv6 addresses. If they use SLAAC, is the implementation using Stateless DHCP or RDNSS?
  • howarthjwhowarthjw Posts: 3 Spectator
    Nov 13, 2021
    I finally got the IPv6 working on the TP Link AX21 working but the fix is really bizarre. I had to replace the TP Link AX21 wifi router with my previous TP Link A7 wifi router. The A7 booted up with working IPv6 using the settings...
    Internet
    IPv6 Internet Connection Type set to Dynamic IP (SLAAC/DHCPv6)
    LAN
    Assigned Type set to SLAAC+ Stateless DHCP
    MAC Clone is set to Use Default MAC address
    This produced a functioning IPv6 as tested on http://test-ipv6.com/. Then I replaced my A7 with the AX21 wifi router (unplugging the D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem) and set it to...
    IPv6 Internet
    No Primary or Secondary DNS set
    IPv6 LAN
    Assigned Type: SLAAC+Stateless DHCP
    MAC Clone set to Router MAC Address: Use Default MAC Address
    which miraculously made IPv6 functional again.
    Nov 13, 2021
    My take on this is that the AX21 firmware doesn't appear to as aggressively clear IPv6 error conditions as the A7 firmware. Alternatively, one could argue that the Spectrum router should be doing a better job of that on its own. So beware of trying settings other than Dynamic IP (SLAAC/DHCPv6) and  SLAAC+Stateless DHCP with the AX21 as you won't be able to clear the resulting error conditions on the Spectrum router.
