GDVR-1004 Error when trying to record series
Icecrue
Posts: 1 Newcomer
When I try and change a series I'm recording (changing record new episodes to all episodes) it gives me an error message GDVR-1004. Any help would be appreciated
Welcome @Icecrue!
Are you running a box DVR, or Cloud DVR?
If you are using a cable box DVR- I would recommend deleting the series, and than re-programing the series to "Record all Episodes."
If you are using Cloud DVR, see this thread::
If your device is compatible, do the same thing recommended for box DVR, delete the series and than re-program the series to "Show all episodes."
