Which cable modem is better?
mmbinder
mmbinder Posts: 2 Spectator
Which cable modem is better:
Arris TM1602a
or
Hitron E31N2V1
any info would help.
thanks!
  • Randy_S
    Good evening and welcome to the Spectrum Community @mmbinder.
    It kind of depends on what you are looking for but I like the Hitron better. Do you have a specific service or capability you are looking at when comparing the two?
  • mmbinder
    I have both. Been using the Hitron for a few years now and Spectrum just sent me the Arris.
    I'm not sure if I should switch though; the Arris seems like older technology.
    HT_Greenfield Posts: 695 Contributor
    Forget about it. Unless your friendly neighborhood Spectrum CMTS is calling for DOCSIS 3.1 for your throughput tier, DOCSIS 3.0 can’t be beat and i’ve never heard a discouraging word about the Arris TM1602A.
