Is anyone else having problems logging into AMC+ right now?
AntDude
AntDude Posts: 182 Contributor
Both https://www.amcplus.com/login/provider web site and iPhone's iOS app fail. I shared my screen shots that I saw:
https://i.broadbandbulletin.com/2025-04-02/1743610457-929189-image.png
https://matrix.zimage.com/_matrix/media/v3/download/ross154.net/jmsfrWzhBmFQNmJaRSdXCkfJ/IMG_6293.PNG
Cable TV is old silver plan. Thank you for reading and hopefully answering online soon. :)
    Satch Posts: 6,158 Contributor
    Hi Ant,
    Try clearing your cookies for AMC+ and rebooting your device. Report back if that helps or still does not. If it doesn't, might be something on Spectrum's end. All Spectrum Select TV plans qualify for the free ad-streaming upgrade, so having legacy Spectrum Silver, (or legacy Spectrum Gold) should not be an issue here.
  • AntDude
    edited April 2
    Now, it works in both devices. I also had to uninstall, redownload, and reinstall iOS app in my iPhone to make it work even though I did that before posting about this issue in here!
