roadrunner login problems
Good afternoon @hondaneill. Welcome to our community. Can you tell me what is happening when you try to login?
choosing the 'website' (Spectrum.net) never gets to the website, the little circle will go round and round, the longest I've let it run is around 2 hours
@jjb3357cvg, can you clear your cache and cookies or try another browser please?
How can I clear my cache when I can't get to the website?
Hello @bhboyett
The process to clear your cache is a little different depending on what browser you're using, but doesn't require the website to load. For Chrome browsers, when you open the browser, there will be 3 vertical dots in the upper right below where you would minimize or close the browser. If you click those dots and select settings, it will open a new tab. In the menu options on the left you would want to select Privacy and Security and then select the Delete Browsing Data.
