Is HBO Go no longer supported? SOLVED, now it's HBO MAX
cdb2001
Posts: 2 Spectator
I can no longer see spectrum as a provider when trying to log in to HBO Go? Did something happen?
6
Good morning! Welcome to the community!
HBO Go was replaced by HBO with HBOmax
play.hbomax.com/login
You would sign in using your Provider and use your normal Spectrum Login.
For Roku, you will need to use the Spectrum TV app, Roku does not support HBOmax
Julia R
11
Thanks!!
