Yankee Stadium
fpefpe
fpefpe Posts: 30 Contributor
edited July 2023 in Spectrum Mobile
Is it me or is the mobile coverage around Yankee stadium really bad? and there are no spectrum hot spots too
    Hey @fpefpe!
    Per our coverage map there should be solid 5G coverage in the area. Are you only having issues there when it is crowded or even other times? We do have hotspots around the area but unfortunately not in the stadium itself.
  • fpefpe
    Hello --- Thanks for your reply ---- I did see the 5G icon on my pixel5, but it was toggling to LTE too -- so could being inside of the stadium cause the phone to toggle between 5G and LTE? --- I looked at the and found Yankee Stadium on the coverage map but it was not clear what I was looking for in on the map
