Difference in HD channels?
OurOwnPlace2022
OurOwnPlace2022 Posts: 1 Newcomer
I would love to know why there are multiple channels with the same HD network? (Hallmark channel 3 times?!) I am using Spectrum app on a Roku 4K UHD tv but do not see a difference between the multiple HD same networks. - Example - local Fox is on 14 as HD and local Fox is also on 915 as HD
    Hi @OurOwnPlace2022, welcome to our community!
    At this time there is no difference, it's just a hold-over from when we used to have seperate standard and HD channels. If you go to either channel now it will just show you the highest quality available. They are not counted as separate channels when looking at the number of advertised channels each package provides.
