What Packages Include The Science Channel?
catchtwentytwo
edited September 2023 in Channels & Programming
I was looking at channel lineups and it appears that none of them (TV Select Signature, TV Select Plus , & Mi Plan Latino) include the Science Channel (SCI). Is that correct? See screenshot below.
    edited August 2023 Answer ✓
    That's one of the dozens of channels covered by the Entertainment View add-on. Hit that from the Channels By Package menu to pare the list down to all of the channels covered by that. Now what few blue dots still show up are merely indicating which few of those channels are also covered by either TV Select Plus or Mi Plan Latino. (I'm guessing that TV Select Signature is more or less the same as TV Select Basic & Expanded.)
    Good evening @catchtwentytwo
    Thank you for reaching out to us about the Science Channel. I am seeing that you should have access to this channel on 112 and 175. It is part of SPP digital tier 1. Please let us know if you have any other questions. -Lyn
