Why does app suddenly stop working?
Jhatf71
Jhatf71 Posts: 1 Newcomer
You updated and changed the app. Now it doesn't even load correctly hooked upto home wifi or Verizon phone.
    Welcome! @Jhatf71
    Try uninstalling and than reinstalling the app, so that you have the latest updates. Sometimes this is needed for the app to work correctly.
