Lost option to cast from Android app
jollyk81
jollyk81 Posts: 2 Spectator
I use this app a lot to cast to a chromecast to play on a large projector screen. Last night I opened the app to find the whole cast icon is missing. I don't see it anywhere. The app is otherwise working.
Was this function intentionally removed?
    Hello @jollyk81!
    Welcome to Community Forums! I'm sorry to hear that you've lost the ability to cast via the app? When did this last work for you? Do you have another device that you can try from? Is the cast option missing on other devices as well?
    Tap on ••• in the lower right-hand corner of the playback frame (if it's not showing, tap anywhere in the frame to reveal it) then tap More Info, and then see if that function shows up there in the upper right-hand corner. If it does, enable it there and then go back. Now to stop casting, tap on the banner at the bottom and go from there.
  • jollyk81
    Don't have it there
