Batch erase recordings
Tdubyu
Tdubyu Posts: 2 Newcomer
edited January 16 in Cloud DVR
Is there a way to select recorded content for batch delete????
    Hello @Tdubyu!
    You should be able to click on the ones that you want to delete and a check mark will appear next to each. Once they're all checked, you can then select the option to delete.
