Peacock Channel & NFL playoff games in 2024
Sridg1968
Sridg1968 Posts: 1 Newcomer
edited February 21 in Channels & Programming
I want to be able to watch the NFL playoffs on these channels
    edited January 14 Answer ✓
    @Sridg1968 & @Olliesmom
    Peacock is a stand alone streaming service, affiliated with NBC, that requires a separate subscription. You would need to download the Peacock app, choose a subscription and then you will have access on a Smart TV, mobile device or other supported device, including Roku.
    Broadcasting some NFL playoff games exclusively on Peacock is a decision made by the NFL.
    Hello @Sridg1968
    Welcome to Community Forums, I am happy to look into this for you. What channels are you referring to specifically?
  • Olliesmom
    Olliesmom Posts: 1 Newcomer
    How do I join Peacock now?
    edited January 14
