Can I use Spectrum Mobile with these specs?? will this be 5G or 4G??
TCO
TCO Posts: 2 Spectator
edited February 21 in Spectrum Mobile
unlocked. can be normal working in your country. CPU -------------  MediaTek Dimensity 1200
Screen ----------- 6.67 inch E4 AMOLED, 2400x1080 FHD + dotdisplay, 120Hz refresh rate
Ram + ROM----- 6GB + 128GB/8GB + 256GB
Camera --------- 48mp + 8MP + 5MP AI triple rear camera, front camera 20MP
Battery ----------- 4520mAh (TYP), support 33W fast charge, in-box 33W quick charger
The -------------- version global MIUI 12 for Poco, support Google Play, Google pay, multi-language and update OTA
Other ----------- WiFi 6, Bluetooth 5.1, GPS, high-double speakers, NFC
Content Package-Poco F3 | power adapter | USB cable type-C | adapter headphone type-C 3.5mm | protective case | tool eject SIM | guide user | card warranty
Network ---------- Netcom full, support dual SIM (slot nano sim x 2)
Supports 5g/4G/3G/2g
2G:GSM 850/900/1800/1900MHz
2G:CDMA 1X BC0
3G:WCDMA B1/B2/B4/B5/B6/B8/B19
3G:CDMA EVDO BC0
4G:FDD-LTE B1/B2/B3/B4/B5/B7/B8/B18/B19/B26/B28A
4G:TDD-LTE B34/B38/B39/B40/B41/B42
5G:n1/n3/n28A/n41/n77/n78
Note: the connectivity 5G may vary based on availability zone and no support operator site.
    Good evening @TCO and Welcome to our Community Forums
    Thank you for your interest in our mobile services. You can check our Bring Your Own device link to determine if it will work with our mobile system. Please let us know if you need any further assistance. - Lyn
  • TCO
    i already know that i can bring my own device.. My question is, if you guys can look at the specs i provided can you determin if the phone will work with your services..
    edited January 31
    We are limited in the scope of support for mobile services.
    For direct support, please contact Spectrum Mobile at 833-224-6603.
