getting channel numbers beside the channels
cfpsherry1
cfpsherry1 Posts: 1 Newcomer
edited March 15 in Channels & Programming
I have tried everything listed here but to no luck. Can you send me a channel # beside the channel. ASAP.
Thanks
cfpsherry1
    William_M Posts: 1,107 ✅ Verified Employee Moderator
    Hi @cfpsherry1, welcome to our community!
    You can visit our channel lineup, which display the network names and channel # they are on. To the right of the page under where it shows your current package, there is an option to Print Lineup which you can use to print or save it as a PDF if desired.
