Why did all my cable box watchlist programs disappear ?
ozznozz
ozznozz Posts: 2 Spectator
edited May 16 in Channels & Programming
As of 04/08/2024 my saved watch list programs all disappeared. Favorite channels and recently watched programs still appear but my entire watch list is gone. Why?
    Hi @Manal
    Our On Demand list can be found online. While content does change depending on what the networks make available On Demand, it's somewhat rare that entire shows get pulled at once. Typically we'd see older seasons maybe get moved to the network's streaming platforms. Are the shows and episodes you're looking for showing up as available in our library?
    Welcome to the Community!
    A software update to the box might be the reason. Have you rebooted the box to see if that changes anything?
  • ozznozz
    Satch,
    Thanks for your reply. I have rebooted the box and nothing I had previously saved before 04/08/2024 was restored to my watchlist. It only contains a couple of new movies I added yesterday 04/11. I'm not that concerned with it but was curious if anyone else had this happen to them and could explain why.
    Thanks again for your input.
    Gene
  • Manal
    Manal Posts: 2 Newcomer
    same here. Many of my shows disappeared from my watchlist and I couldn’t even get them back when I looked for them. What happened to Chicago med and Chicago fire? What about Family law? Can’t find them anywhere
  • Manal
    The shows on demand seem to have reduced significantly
