Where is Court TV in 2026?
toddy5000
toddy5000 Posts: 1 Newcomer
edited January 7 in Channels and Programming
Court TV was channel 465 WRDQ2 before the new year. The programming guide still says it is Court TV but it is showing "GRIT" channel programming instead of Court TV meanwhile channel 17 WOTF GRIT is showing "BOUNCE" programming. I cannot find Court TV anywhere on Spectrum even though it is available on internet sites like youtube.
edit: if it helps my location is Brevard county Florida(same channel lineup as Orlando area).
    HT_Greenfield Posts: 1,293 Contributor
    WRDQ's ATSC channel 27.2, aka WRDQ2, still simulcast on Charter Spectrum TV channel 465, is presumably now affiliated with "Grit." 🔗 https://www.grittv.com/find-us ↳ enter Brevard County zip code e.g. 32909 in the search field and then hit the search hyperlink.
    Which would be consistent with Spectrum TV now carrying something else on channel 17 e.g. maybe now simulcasting WOPX's Bounce-affiliated ATSC channel 56.2. 🔗 https://www.bouncetv.com/findus/
    Court TV is presumably now only available in the "Orlando-Daytona Bch-Melbrn" area via WOPX over-the-air channel 56.3. 🔗 https://www.courttv.com/find-us/
    That's not the issue, here. I still get Court TV via Spectrum TV simulcast of a local channel. I stated the issue in the last paragraph of my previous comment. No offense but how deep do you think the inquisitor wants to go on this.
