Can’t access my email @stny.rr.com
Dkalmen
Dkalmen Posts: 8 Novice
I was trying to check my email today @stny.rr.com and cannot. I was prompted to se up email @ spectrum.net. How do I get my email from @stny.rr.com? I need those emails.
    Hello @Dkalmen
    Welcome to our community! To access your emails, you would need to log in at https://www.spectrum.net using the full email address and your password. If you have any difficulties, please let us know!
  • Dkalmen
    I tried signing in with the full email address and it did not work.
  • Mo_S
    @Dkalmen you're using the full email with the stny.rr.com domain to log into spectrum.net? I see the same email user using the spectrum.net domain as well, which is the primary Spectrum ID.
    If you're using the full stny.rr.com email to log in, what issue did you have logging in? The email is active as well as that Spectrum ID.
  • Dkalmen
    the system would not log me in when I typed in the full email @stny.rr.com
  • Mo_S
    @Dkalmen did you get an error, or need to change the password? What did you see?
  • Dkalmen
    I get this message: the info you entered doesn’t match our records. IDID 3104
  • Dkalmen
    I am typing in the correct email and password
  • Mo_S
    @Dkalmen that references invalid login credentials for the ID you're attempting to log into. If you're unsure on what the valid details are, you can use the Forgot Username or Password option below the sign in fields.
  • Dkalmen
    I’m using the correct email and password for @stny.rr.com and still get that message. It will not let me check that email. All my doctors, friends send me emails at that address. I need to access it.
  • Dkalmen
    when I type in spectrum.net/?targetUrl=webmail2 it automatically takes me to I’d.spectrum.net. That website is where I pay my bill and has a different login. I cannot access my @stny.rr.com email on that website. I need access to my email @ stny.rr.com. This needs to be resolved.
  • Dkalmen
    I called Spectrum and the technician fixed the problem
  • Mo_S
    @Dkalmen
    That is the correct website, and you'd enter your email address there to access it. I do see you called in, were able to change the password and successfully sign in. If you have further issues, please let us know.
