Toggle to a specific page on email inbox
tombstone
tombstone Posts: 4 Spectator
I have a rr.com email acct which I have had for 20+ years. When I look at my inbox, I have over 100 pages of emails which I have saved for various reasons. Is there a way I can go to a specific page in my inbox? Currently, the only option I see is at the bottom of my email page (which list the first 20 emails) is " — Previous 1 2 3 4 5 … 129 Next — ". Is there no way to select a specific page, say page 50. Currently, the only way I can find to go to page 50 is to click page 5, then go to page 50 one page at a time. Hopefully there is a better way???
    Edward_T Posts: 571 ✅ Verified Employee Moderator
    Hello @tombstone;
    Thank you for the feedback on our webmail. We currently do not have an option to select the other pages but you can adjust the number of messages per page that will reduce the amount of pages you are seeing. You can also use the search function near the top if you need to find a specific message. I will pass on your feedback about the webmail to consider adding the feature.
  • Mo_S
    Mo_S Posts: 542 ✅ Verified Employee Moderator
    @tombstone,
    For me, when accessing my own rr.com mail via spectrum.net, at the bottom of the email inbox you can select the page and a drop down appears where you can choose any specific page.
    As an alternative, you can also modify the end of the webpage URL to change "page=##" to the number of the page you want to visit.
  • tombstone
    Edward_T. Its strange that Mo_S shows how their their email appears to allow for page selection, but you say it does not exist. I cannot see what Mo_S posted. Perhaps my Settings are different. Are rr.com and Spectrum email formats different? Also, for some reason, when I use the search feature, if I get a return of more than one email, I can only select and read one email. The system will not allow me to click on any other emails in the Search list unless I do another Search, then click a different email. This gets aggravating if I get more than a couple of returns on a Search. This happen on both desktop and mobile devices.
    Mo_S, I also could not find the page selection in my URL. I even copied and pasted it to a Word doc and did a search for it. That URL has about 2000 characters.
    I was able to change the settings so that 100 emails were shown vs 20, but still not very efficient.
    You should be accessing our email by logging into www.spectrum.net. You may see a different view when you access it on that site. We are no longer using the old webmail site and email accounts have been set to be used only on www.spectrum.net. You may not be seeing the URL text due to using our older site.
  • tombstone
    Yes, I am using the new sight now.
    Your browser may not be displaying the full URL. You can try accessing the site on a different browser to see if there is any difference in the view.
  • tombstone
    I opened it in Edge and Chrome and they both look the same. Safari on my phone even looks identical.
    HT_Greenfield Posts: 1,327 Contributor
    edited February 3
    Edit: @tombstone : I guess you're referring to the webmail.spectrum.net U.I. pagination presentation.
    🔗 https://www.spectrum.net/support/internet/setting-email-viewing-preferences-bhn-twc ↳ List View
    P.S.: In the meantime, i guess you could make it all more painless by organizing the all the messages into multiple separate folders of no more than, say, 500 messages each.
