Any estimate for High split timeline (34759)
Hi, I live in 34759, Osceola County, FL. Is there any info you can share with me?
    Hello @NotTheGiant;
    Welcome to the Community Forums. I checked the status for the upgrade in your hub and currently we do not have an estimate on when the work will be started. This indicates that it will be at least 6 months before the service will be enabled.
  • NotTheGiant
    NotTheGiant Posts: 2 Novice
    OK, thank you!
    You're welcome.
