Dvr
Sdlurie1
Sdlurie1 Posts: 1 Rookie
I have a smart tv and use the DVR cloud service to record shows. This has been working fine, but one of my shows that airs on Tuesdays at 8pm isn’t recording. There is only one other thing recording at the same time and I have nothing stored—as they are typically watched and deleted right away. If I go to the program through the search it says it is set to record the series, new episodes only—but it never does and if you go into the future recordings it isn’t there! I don’t get it!!
Anyone else have this problem or know how to fix it??
    Hello @Sdlurie1
    Welcome to our community! What program on what network are you having the issue with? If you try to set up a recording for a different show on that network does it record?
