High Split upgrade for Los Angeles (90292)
dmoosie
Posts: 1 Rookie
Hi there, Do you have any status updates for when high split will be coming to Los Angeles/Marina del Rey zip code 90292?
Hello @dmoosie;
Welcome to the Community Forums. I checked the status of the upgrades and we currently do not have an estimate on when the work will be started. This indicates that it will be at least 6 months before the work will be completed and enabled.
