Sim Card
LJPotter64
LJPotter64 Posts: 2 Novice
I received an email that my sim card was transferred to a new device
  • LJPotter64
    Hello, I did not authorize my sim card to be used on a new device
  • Tyleen_Z
    I do apologize for the issues. The forums are for peer to peer support and most account issues cannot be resolved from here. For this type of issue I would suggest to call in to the mobile team directly at 1-833-224-6603 to get this looked into quickly for you.
  • Mo_S
    @LJPotter64
    The notice you received appears that the active SIM card was installed on one of the deactivated lines on your account. When you call, they can go over what SIM card belongs with which device if it's not matching up.
