transition from satx.rr.com to spectrum.net
rgreenii
rgreenii Posts: 1 Rookie
I did not respond to the message that a new email address was being assigned. Now I have time to deal with this, but I cannot find the message, nor can I find anyway to make this change. At this time I am using my original email address ending in satx.rr.com.
  • Mo_S
    Hello and welcome @rgreenii,
    The legacy email domain (satx.rr.com) isn't being changed. You can continue to use it by logging into spectrum.net with the full email address and password to check email. You do also have another RR email account, as well as one with a spectrum.net domain, which is your primary user ID. If you no longer want the RR email account, you can disable the ID associated with it.
