Getting SMS messages on my landline phone
deedleann824
Posts: 251 Contributor
in Voicemail
How can I enable readable voice mail? i.e. Instead of a text message, it will send a voice message instead.
Hello @deedleann824;
Visual Voice Mail setup can vary depending on the phone you are using. You can visit the following site for information on how to set it up. You will need to select your device for the instructions.
I have a landline phone, none of the brands shown. My phone is a Radio Shack.
I'm not aware of any landline phones much less any fixed VoIP service that supports SMS text messaging but here's how to enable "readable voicemail":
🔗https://www.spectrum.net/support/home-phone/enhanced-voicemail-help ↳ Readable Voicemail 🔍👀
