(Re)activating AMC+ app when changing plans
GC1950
Posts: 8 Participant
This is not a question, just a heads up. I have the AMC+ app installed since AMC+ is included with my TV plan, but discovered that if I switch between ad-free and with ads versions (going either way), it is necessary to log out then back in. Otherwise AMC+ doesn't properly recognize that your subscription through Spectrum gives you access.
I will add that this may only be an issue with Apple devices. I had to log out then back in on Apple TV and iPad, but the Vizio app was fine.
