I have recorded 20-plus tennis matches How can I batch-delete the entire group?
kfoss
kfoss Posts: 4 Novice
    edited September 16
    Hi @kfoss, welcome to our community! The steps will vary depending on the device you are using. On SpectrumTV.net and Android or iOS devices, go to DVR > My Recordings. On Roku and Apple TV, go to My Library > Recordings. Select the series you want to delete and select "Cancel Series". You can refer to
    Keep in mind you don't have any limit on the number of total recordings with your Cloud DVR unlimited, so you don't actually need to delete anything to free up space, only if it's an annoyance to scroll past.
  • kfoss
    link = Page Not Found
  • Katrina_L
    Katrina_L Posts: 200 ✅ Verified Employee Moderator
    edited September 16
    We are sorry about that, here is a working link https://www.spectrum.net/support/tv/how-record-and-view-programs-cloud-dvr
  • kfoss
    Thanks, William. My question is about deleting existing recordings, not canceling future recordings of a series. For example, after a tennis tournament I may have dozens of individual matches already recorded that I no longer want. Is there any way—on SpectrumTV.net, iOS, Roku, or another Spectrum interface—to select multiple existing recordings and delete them in one operation, rather than opening and deleting each recording individually? I understand that Cloud DVR Unlimited has no storage limit; the issue is keeping the Recordings library manageable.
    Individual recordings need to be deleted separately, one a t a time. They will automatically delete after 90 days. I find it is easier to use a mobile device or laptop with a touchscreen and swipe to delete, as opposed to the Smart TV or Roku interface where you need to navigate with the remote.
  • kfoss
    Thanks. Seems pretty strange there isn’t a batch-delete feature since it’s standard on other services and apps. Would be used by many customers.
