High Split Status 45661
What is the highest split rollout status in southern Ohio? Specifically in the 45690 and 45661 zip codes.
  • Katrina_L
    Katrina_L Posts: 211 ✅ Verified Employee Moderator
    Thank you for your interest in our High Split upgrade. I am not showing that this has been activated in your particular area at this time. Once this is an option you will receive notification to your preferred method of contact. Please let us know if you have any other questions.
  • dgboyer
    dgboyer Posts: 2 Novice
    Any estimate on when that might happen?
    William_M Posts: 1,843 ✅ Verified Employee Moderator
    It doesn't look like work has started in your area yet and there's no set date for when it will, so it is likely still 6+ months away.
